DutchGFX
- Dec 1, 2012
Ahhhh, I understand. So I need to test every connection while shooting power threw 1 conductor to ensure the others are separate
Just to make sure that I understand what you're saying: So even if I wanted to upgrade to a silver cable, on a single entry style headphone, rewiring from entry point to the other driver wouldn't be necessary? Wouldn't that change the sound from source to far cup due to the different cables? I am quite naive when it comes to recabling, so I just want to make sure that I do it right
Though with AKG headphone, it is interesting. The two metal rods making the headband are used to carry signal from one cup to the other. These rods are probably made of a metal alloy chosen for its physical properties, not electrical ones. Then there are small wires soldered to the ends of the rods. So in practice, the right driver's signal has to go trough 4 additional solder joints and long metal rods. It may be interesting to measure the total impedance of this system. It may be significant.
Skip to 2:41 and then 4:20.
I am not sure it is fully balanced when you only have one cable coming out of one side~~~
I think a Y split will be a better idea here cause different length and material of the wire will lead to different resistance. If you care that much to turn the AKG into a balance setup, the last thing you will want is the channel imbalance caused by different wire resistance.
P.S.
The cable looks very nice!
