Earwax
- Aug 31, 2003
I have a Griffin dock for Sansa Fuse. I'm really not happy with the sound. Especially in lower range it is more muddy than just taking audio from the headphone out jack of the Fuse. So I decided to take a look at what's what inside the dock.
Next to the USB port, C3 and C4, I think, are power supply bypass caps. I don't think there's any reason to change those?
R4 controls brightness of the overly bright D1. I'm either going to put a larger value resistor in there or mechanically block some light from entering the little light pipe.
On the headphone jack side there's series caps C1 and C2 and 100K resistors R2 and R3 after the caps to ground. There's not a lot of room inside the dock to replace caps. I was thinking of just trying to tack on some sort of bypass cap with what's already there. I have some Russion PIOs, the smaller values might fit in there. Or I probably have some MKTs laying around. I was hoping to try some Aerovox but the ones I have appear to be to big.
If I take the existing caps out, the only thing I have on hand to replace them would be a panasonic FM and there might still be enough room for some small film bypass cap.
I don't want to destroy the board with repeated soldering installing different combinations, so I'm open for suggestions.
I did look at some of the ipod dock threads, but they all seem to use huge expensive caps. Think low budget.
