gerG
Someone on this very board pointed me at this gem, but I forgot who, and I can't find the thread. Whoever it was, thanks!
BlueParamEQ is a very capable and useful parametric equalizer that works through the AdaptX plugin for Winamp. Give it a shot.
Get Winamp 2.9 from this site:
http://classic.winamp.com/
On that same site you can get the AdaptX plugin (under plug-ins, DSP/effect).
You also need the equalizer from this site:
http://www.directxfiles.com/plugins.htm
Go to manufacturers, then scroll down to Digilogue. You can get the whole blueline plugin pack, or just the EQ.
The AdaptX plugin creates it's own manager window, and you load the directx plugins there. The trick is that you can load a module, mess with settings, and nothing will happen. You have to select the little box to the left of the name of the module to make it active.
Also notice the little tabs at the bottom that let you select the graphic view which lets you see and adjust the equalization curve. Very useful! Also the meters are great, with a running estimate of headroom (adjust with the preamp control, and hit the R button to restart the headroom number).
That should be enough info to get you in trouble for now. I will get around to posting some suggested starting points for different phones one of these days.
Have fun, and if you find any other useful directX plugins let us know!
gerG
gerG
