anwaypasible
- Aug 9, 2009
hi..
first of all
i have some grado sr60's and i am seeking to put the finishing touches on these headphones by exploring what i can do to make my headphone's run at full potential.
i have an xpsound pre-amp (with headphone amplifier built-in) that i use with a shure es(sum'n sum'n) calibration mic that i use to calibrate my 5.1 setup (and i will be using the same setup to calibrate my car audio sound system in the future with a laptop and the help of truerta)
the xpsound claims to put out 11 milliwatts:
XP201 Specifications
These test were made using 'Right Mark' audio analyzer software and the new 24bit/192kHz Waveterminal 192X PCI audio card from ESI.
- Line level frequency response: 4Hz - 44kHz +/- 0.1dB
- RIAA frequency response: 20Hz - 20kHz +/- 0.5dB
- Headphone Level: @550-ohm 21 milliwatts, @32-ohm 11 milliwatts
the sound from the grado sr60's while using the xpsound is noticeably louder (slightly) and more refined (a bit).
i am searching for the thermal specifications for my headphones, because i think this xpsound headphone amp has only nudged the 'more-refined' sound that is capable from amplifying higher-quality headphones.
and i am comparing the sound of the grados between using the xpsound and again using the internal laptop's headphone-out output.
the laptop is like 7 years old and uses (what i think) is an AD1886A: AC’97 SoundMAX® Codec from analog devices.
i have no idea what the electrical output level is on this laptop.. but it isnt a whole bunch less than the xpsound.
i have two other options to power these grado's.. my big computer (that is in storage at the moment) and my home audio receiver (that is also in storage at the moment)
i'd like to feed these grados with the most unclipped power that they can handle (and then turn them down if necessary)
so does anybody know the thermal spec's of the coils??
QUESTION NUMBER TWO:
i am using the xpsound for now (and even with the laptop's output) i am experiencing ear fatigue in the upper treble area's.. and i dont know if that fatigue is causing a lack of detail in the midrange area (or if i need to bump the equalizer up).
does anybody have a calibrated frequency response on their equalizer for the grado sr60's ?
if so, can i get your EQ settings for reference.
i've got a severe 'aluminum' problem and i lowered the 'average ear canal resonance frequency of 7400hz and the fatigue took one step in the right direction, but there are other sliders that are needing adjustment.
i really dont want to use truerta on this laptop's 16bit analog to digital chip with a crumby 87dB (89?) range
i have been trying to blame the 16bit audio of this laptop as a culprit of the 'tin' sound.. but i havent pulled my big computer out of storage to compare.
if i had it my way.. i'd put an oscilliscope to the laptop's output and find its maximum before clipping.. then i'd find the xpsounds maximum before clipping and seek the equalizer to drop the peaks first (quick double check to see if there is any clipping) then add boost with the equalizer (while checking for clipping after each boost, making any adjustments necessary).
i've got two things keeping me from doing that..
1. i dont have an oscilliscope yet (i want it for car audio/home audio)
2. i am missing one of my headphone-to-rca adapters (so right now i can only output from the laptop - or input, not both at once)
and the ear fatigue is bad.. i am certain that i keep wanting to turn up the power to hunt down the defined details, but i need to get rid of these nasty peaks first (lots of fatigue).
anybody know what i'm talking about and can help?
this forum looks rather 'above-average' so i'm hoping for some exciting results.
first of all
