wallstreet
- Feb 14, 2002
I don't know if this has been mentioned but I think the size of the plane your traveling on makes a big difference. Smaller planes are very noisy, especially if you're near an engine. If you get a seat a good distance away from the engines and are on a bigger plane I think you can get away with the sr60s as long as you can listen at lower volumes to not irritate the person beside you. You are still going to loose a lot of detail to cabin noises, so any isolation would be prefered over none.
edited:grammar
Originally Posted by Ace o' Spades How bad is it to listen to music on an airplane with Grados? I need to decide if I want to bring my super.fi 3s on vacation for use on the airplane for the isolation. Thanks! |
edited:grammar
