Michgelsen
- Apr 2, 2007
I am also using the Grace as a DAC with my Stax system, and it works beautifully.
Has anyone compared the Grace m9XX to the new Micro iDSD Black?
Should I get the m9xx if I Already own a Mojo? is it considerable different? better somehow? I need a good desktop Dac/Amp for around 5-700. Any suggestions?
Sound wise they're basically identical. I like the features and form factor on the m9XX better than the Mojo. If you want a more functional desktop version of the Mojo, that's basically what the m9XX is.
Hmm, Theres one available on ebay for $450. I was seriously considering it, But if its identical to my mojo soundwise, then it doesnt really make sense for me to buy. Do you have any suggestions for a desktop DAC/AMP combo for around $600? I'm not a big schiit fan though. And yes I'm in the US.
What headphones?
Right Now, I'd be using the 400i's and X00's. But Planning on getting LCD2 soon. hence the need for a desk dac/amp because I doubt my mojo would power the LCD2 well.
My rec in that price range wth those headphones would be gustard H10 + Modi Multibit.
Alright! Thanks, looks good! I will have a look. this combo would fare much better than the grace?
The H10 is certainly a more powerful amp and is discrete. And the Modi Multibit is a touch more detailed than the DAC in the m9XX. The m9XX DAC will have a little bit more oomph in the transients than the Modi Multibit, but the H10 should more than makeup for that. The H10 is an extremely dynamic amp, that just plows through hard transients with effortless ease.
Where the m9XX will win out is footprint and looks. The combo of the Modi Multibit and H10 will look a bit odd compared to the sleek, single small box of the m9XX. The crossfeed built into the m9XX is nice as well. But yeah, in absolute sound quality and ability to drive all your headphones, the Modi Multibit and H10 should win out.
another question I had was that massdrop asks you to choose a 'power supply 110 or 220v' . is that just a simple 5v/2a PS? If you get a 110v and I have to use it in a 220v area, will you have to use a step up transformer? or basically any Mobile phone charger can suffice?
yep, you can use any 5v/2a PS (almost all mobile phone chargers are this). I actually have 5v/2a USB outs built in to a few of my power outlets and use those for the "power only" side.
