nicholars
- Aug 28, 2011
In my new PC I have a GTX 970 graphics card which buzzes during gaming, this is reasonably normal for these cards and I am not bothered about it (I have had 4 and they all buzz), however the buzzing is picked up on my speakers when the amplifier volume is turned up.... here is the strange part, when my TV is connected to the amp via a 3.5mm > Dual RCA cable (for listening to normal TV through speakers on a different input selector on front of amp to PC), the buzzing interference sound is about 5x louder, and when I unplug the 3.5mm cable from the TV the buzzing is inaudible at anything other than slight buzzing at 100% volume on the amp (I also have my PC connected to the TV via HDMI on GTX 970 which I play games on).
So I have ordered a Fiio D03k to connect the TV to the amp via the optical port > Fiio D03k > RCA cable > amp, I am thinking this will probably stop the problem of the 3.5mm > dual RCA cable amplifying the interference from the graphics card, I do not entirely understand why it does this, I think it might be something to do with a ground loop but I do not know enough to understand properly, anyway I have a feeling the optical > DAC > amp will fix the problem as optical cables are known to be good for stopping interference or ground loops as they are not conductive.
If the fiio doesn't work and I cannot find any other solutions, I will be forced to sell the Xonar STX and buy an external DAC to have the TV and PC (xonar STX via RCA out) connected to the amp at the same time without loud interference during games, which I would rather not do.. So if the fiio doesn't work is there anything else I can try? I was thinking of putting ferrites somewhere and seeing if that helps.... Not sure what else I can do to diagnose / fix the problem, its definitely from the graphics card because the sound through the speakers matches the tone of the buzzing from the graphics card (which changes tone when moving mouse in games etc.. and the speakers make the same noise).
If the fiio D03K via optical does fix the loud buzzing (which I have a feeling it will as unplugging the 3.5mm cable from the TV stops 90% of the buzzing noise) and I am left with a very small amount of buzzing that is inaudible at normal volumes... Is there any chance this could damage my precious amplifier or speakers? I read ground loops can damage equipment, but when the 3.5mm > RCA cable to the TV is disconnected the buzzing is non existant until 75% volume and slightly audible at 100% volume on amp, so does not cause any problems as I never go past 60% volume anyway and even at 100% it is not loud at all, do you think this is still something that could cause problems or damage the amplifier and needs fixing another way?
The buzzing when connected to both the TV and PC is noticeable at 30% volume and very obvious at 100% volume, when I unplug the 3.5mm > dual RCA cable that connects TV to amp, the buzzing is really not loud at all even at 100% on the amp, but it still bothers me a bit as it should not buzz at all at any volume. I don't know anything else I can do other than the optical cable or ferrite chokes. Can anyone with more knowledge of this sort of stuff give me any advice please?
