spike33
- Jan 18, 2005
I got the drivers installed and found the u24 control panel but can't find the asio control panel described in the manual? how do i access that?
also, on foobar, i can't get asio working, i get this error:
INFO (foo_output_asio(exe)) : open : 44100 Hz, LINEAR PCM, 24 bits, 2 channels
INFO (foo_output_asio(exe)) : ASIO device type [channel 0] : Int16LSB
INFO (foo_output_asio(exe)) : ASIO device type [channel 1] : Int16LSB
ERROR (foo_output_asio(exe)) : unsupported output data format.
help plz?
help plz?
