My drive was delivered today!
It's the Multspin 3Xp Plus, not the six. Besides the speed difference, it has only one scsi connection, is top loading, and has a headphone jack on the side but no rca jacks on the back. Also, it does not seek through tracks, but that is not very important to me. Without a dac, the improvements I'm hearing are subtle
most of the time. However, I have already found a few tracks with fairly noticeable differences. (I'm comparing this to my SB Live, with both sources going through my vintage reciever.)
What I'm hearing with the 3Xp is
A) A smoother presentation (the SB Live sounds somewhat harsh in comparison.)
B) More neutral sound (this is very closely related to item A, as it seems like the less neutral response of the Live magnifies harshness in the midrange.)
C) Wider soundstage (to be precise, a headstage that is both wider and slightly deeper, extending further behind my ears than with the Live.)
D) Better instrument seperation.
E) Possibly better resolution, although this could be a result of items A and B.
I'll listen more and post more impressions later, but I'm quite happy with the drive so far. I'll be even happier when I get an Art DI/O.
Edit #1: The 3Xp uses a wall wart, so upgrading the power supply is as easy as buying a better wall wart. What is difficult is determining which wall warts are better, as the supplied one is both large and heavy. t does not say, but I think it may be regulated. I will have to try to test it later.
Edit #2: The whole transport is mounted on some sort of shock absorber, allowing it to remain stable even if the housing is jarred. I will report more on this after I open 'er up.
