KR...
Curator of the Headphone Lust Museum
- Jun 22, 2001
I edited my post above so that it would show the version that you have, or not. LED light, does it come with the RC?
Oh, the other stacked amp is this :
HEADMASTER PRE-AMPLIFIER
The SUGDEN HeadMaster is a dedicated Pre-amplifier and Headphone amplifier with exceptional qualities of musical performance. It has been specially developed to extend the boundaries of audio pleasure into the ultimate near-field listening conditions. It is suitable for use with most commercial headphones.
The unit is equipped with three stereo input facilities, a parallel tape output, and a switched pre amplifier output. These facilities create a very flexible piece of equipment, which can operate as a stand alone dedicated headphone system or be combined as a high quality pre-amp in a total audio system. The special design features of the amplifier circuitry have been incorporated to enhance headphone performance but also facilitate a very high quality pre-amplifier performance.
The amplifier signal path configuration is pure Class A constructed completely from discreet components. The application of the Class A circuit has been optimised to obtain its characteristic benefits of superb low level listening and low distortion. Particularly important to the use of headphones is the inherent avoidance with the Class A configuration of odd and high order harmonic distortion. The amplifier is wide bandwidth with a very neutral and transparent sound stage through the full musical spectrum and volume range.
Specifications:
Inputs: Three stereo pairs.
Input Impedance: 50K
Input sensitivity: 150mv in for 1volt output
Outputs: Switched headphone socket / Attenuated Pre Amp out Tape-out
Output Impedance: 4Ohms to 56kOhms
Power output: 5.5volts at onset of clipping
Bandwidth: -3dB points 10Hz & 270kHz
Frequency response: +-0.3dB 20Hz-25kHz
Signal to noise: > 90dB
Dimensions: 230mm x 265mm x 82mm [wdh] weight 3.5kg
NOTE: The Headmaster has now been upgraded with a Sugden RC5 remote control handset.
Specifications:
