Originally Posted by Audio18 Wouldn't work with Foobar set at 24 bits with Kernal Streaming but works at 32 bits, any ideas?
Actually, you need to select "Show all settings" in the box next to the quantization ("bitrate") settings. Then, after you get to the dropdown list, select the "24 bits padded to 32 bits" setting.
yup tried that, gave me same error as when i tried 24 bit
EDIT - NM, it works but then when i restart foobar and open it there is nothing at the place where i see Output Data Format than the XX Bit part is blank. i have to click show all options to see that it says 24 bit padded to 32, is this normal?
Originally Posted by Audio18 yup tried that, gave me same error as when i tried 24 bit
