Mhog55
This. If you want an easier to drive closed back, you could look into the Audio Technica ath Msr7b.If you want something similar to the 660s at $150 then it's the 58x no questions asked.
Thank you, but I'm looking for an open back. Right now.This. If you want an easier to drive closed back, you could look into the Audio Technica ath Msr7b.
58X is similar to the 660s (own both). 660s is a little more detailed and neutral. 58X has more low end and low mids. I prefer the mids of the 58X, and listen to them more than my 660s.Thank you, but I'm looking for an open back. Right now.
Thank you!58X is similar to the 660s (own both). 660s is a little more detailed and neutral. 58X has more low end and low mids. I prefer the mids of the 58X, and listen to them more than my 660s.
Just to comment on the comfort portion since you've mentioned that was a concern, I find the 58X more comfortable than the 4XX overall. You might find that the clamp force on the 58X at first can be a bit tight but after a while they're much more comfy imo, especially with the headband padding on the 4XX being basically nonexistent.
thank you, i will look into it.I like my hd600 for long listening sessions. Ive also heard good things about the harman neutral K371, that should be right at your budget as well.
