DJGeorgeT
- Mar 5, 2004
Geez thanks for that recommendation from utopia. I'm pretty sure you have no clue. There is no such thing as "flat frequency response". You may find a headphone that in your opinion sounds balanced, but all headphones have their own "sound signatures". Nothing wrong with it. But good and widely used monitors include the MDR-V6, MDR-7506, K204S, and others. I have tested the V6 against my mackie monitors and they are highly comparable and widely used for the type of music I am producing...I can only do a direct comparison of material I am working on. FYI, nothing replaces monitoring speakers such as a good pair or Alesis ones. Some producers play their stuff on many different systems as well. In the club, in the home system, through the monitors, etc. I think a good chunck of work can be done with headphones, but it is not final. Some of us refer to "analytical" as in not veiled or rolled at the high end. I am not talking about exagerated top end.
Originally Posted by bigshot I can't believe some of the advice in this thread. I guess some people just aren't familiar with what sound engineers need in a set of cans. It doesn't matter what type of music you are monitoring... electronic, acoustic, rock, classical... It doesn't matter if you personally like lots of bass or treble either. The last thing you want are cans that are detailed or analytical. You don't want ones that have a sound signature that suits a particular type of music either. What you need for mastering are balanced headphones with a *flat frequency response*. Otherwise, you'll end up with music that sounds fantastic in your cans and sounds totally bizarre when you play it back on speakers. The point of monitors, whether they be speakers or headphones is to provide a baseline. The only way to determine whether headphones are good for monitoring is to compare them to the output of a known source... ie: good monitor speakers. See ya Steve |
