DoctorGonzo
- Dec 1, 2011
Hi,
I'm new to the forums. Just found them while doing some research about the Goldring DR-100 Cans.
I bought some yesterday on sale from Super-Fi for £21.95 which I thought was a pretty good deal considering the build quality. All-in-all I like the fit (I prefer a tight fit) My problem is, They're so quiet and produce hardly any bass. Granted I am using them with my PC's onboard audio (Realtek ALC888B)
Bit of info before I ask for some advice: I'll only be using these with my HTPC and listening to 320Kbs Rips of my CD's and watching Blu-ray movies.
My question is, what would be the best way to get the most from these Cans on a buget? A Fiio E5, ASUS Xonar DG or my other option is a new Gigabyte Motherboard that I have hanging around waiting to replace the one that's currently in my HTPC. The new motherboard has Realtek ALC889 onboard audio, would this drive the Goldrings better than the older audio codec?
More info on the new Motherboard: http://www.gigabyte.com/products/product-page.aspx?pid=3743#ov
Any advice would be most appreciated.
Cheers
Cheers
