Copyright
- Nov 10, 2008
For whatever reason when I go into games I get a wierd humming buzzing type of noise through my speakers. I use a balanced to RCA cable to my JBL speakers. Finally got the noise reduced using a ground loop isolator. My Audio Outlaw 8" Subwoofer has hum even when the input isnt plugged in. I think some of my issues are the power from teh wall. What is crazy is if I remove my battery backup the speakers all go crazy with noise. My Sound card is a Sound Blaster ZXR. I know Breakers trip in my room really easily I think this is because of the GFCI breakers used which I wonder if they are causing noise. I have never had problems like this before on any PC I have owned.
