For an update to the above, I was able to replace the Gilmore Lite DPS LED effectively, after getting around to learning about some soldering basics. I have now found the the LED of the DPS is
much dimmer than that of the amp (albeit now the correct color). I assume the LED current limiting resistor of the DPS now needs to be changed to a lesser value. If anyone has any advice as to what that ohm value (or color labeling combination) is, I am all ears! In the
http://www.head-fi.org/forums/f6/changing-led-483411/ thread, which I started to discuss switching the LED properly, I have brought up another query. Based on the pictures of the circuit boards on the Headamp site, is it possible to glean the proper ohm value of the DPS LED resistor? (This is assuming that the supply voltage is the same for both components.) I am having a hard time making out the colors, as detailed below. If anyone knows better than what I have figured out so far, please let me know. Thanks!
From the initial thread:
I figured that I would be able to look at the blown-up pic's of the GLite chip boards on the Headamp website to see what the color indicators are on the resistors. I'm starting to think that I am colorblind, because I cannot decide what the colors are of each resistor's bands.
For the GLite:
http://www.headamp.com/home_amps/lit...board_high.jpg (click to 'zoom')
The resistor, which is just to the top-right of the LED looks to be violet ['7'] - green ['5'] - blue ['6'] - red [x 10^2] - violet [+/- 0.1%] = 75600 ohms?! (This seems extremely high, especially since the GLite LED is the brighter of the two.)
For the DPS:
The resistor, which is to the bottom-right of the LED looks to be violet ['7'] - green ['5'] - black ['0'] - brown [x 10^1] - brown [+/- 1%] = 7500 ohms.
Again, I am fairly sure that I am not seeing the colors for what they are truly supposed to indicate. If you have a second and know your way around resistor nomenclature, feel free to check and validate/dismiss my measurements. Thanks in advance!
