pin 7 of OPA227 is intended to be hooked up via jumper(in order to turn BB on and off, or possibly use it as a 2channel section |
Oh...Could you explain this in more detail?
I can't quite see what it is you plan to do. Don't the 227's need power always?
I'm working on a switchable Gilmore myself. Here's my plan.
So, I'll have a standard Gilmore amp
with the layout excately as yours.
Except that pin 7 of the 227's are connected
and pin 3 is not. I'll refer
to this as the "positive" board.
Another board, the "negative" board, will accomodate the
negative output.
For each channel on the positive board,
from the appropriate pins on the fets,
I'll lead two wires A and B to the negative board.
These lead to the transistor banks.
I'll also lead a wire C from
the + input of the 227 (pin 3) of the positive board to the negative board.
For each channel,
a switch will put the three wires into one
of 2 configurations:
1) (normal) A and B are broken, and C goes directly to ground.
2) (bridged) A and B are unbroken and C ties to the extra cap needed for bridged mode.
I suppose power for the negative board also
needs to be switched...
Sorry if this seems confused....
And this all seems unnecessary too...
Why not have the amp in bridged mode always?
One can then use the two + outputs
for normal headphones (would the
two - outputs work?), or use both the
+ and - outputs for dual mono. A 4 pole
double throw switch would accomodate
this setup....
I've also toyed with the idea of converting
the + and - outputs into a single ended output using this circuit
http://sound.westhost.com/project51.htm
(for use with normally wired cans, of course);
but I'm afraid sound quality
might then be compromised.
Any comments would be
appreciated.
