Xander
The XanMan is back!
- Sep 22, 2001
I don't do too many interesting projects that often anymore, but I figured this one was unique enough to add. Not sure if it's been done before, though I'd bet it has.
Not really DIY.. Sortof a mutilation project. Whats inside that you can see, is a OpAmp based amplifier, sortof like the cmoy but with a lot more balls. Changed the economy DAC to something much better, and fiddled with opamps in output stage too, as usual. Sounds a bit better than you're average stock CD player for about 130 dollars, but for $8 at a thrift shop + parts, not at all bad sounding! And a built in headphone amp, who can go wrong! I also mounted my own pot, as apposed to utilizing theirs (cheap) and used the existing headphone jack, though removed the pop-click filter they had on it, which sucked the life out of any signal passing through it.
I appologize for the horrid pictures, I have to post them locally on the server since I have no web space to put them, so the size and quality is limited, but it'll give you an idea of the horrific things done to this poor little player....
