i_don't_know
- Oct 4, 2008
But with much wider and more realistic soundstage. I also want them to be very quick, but at the same time have super realistic decay (so if a note is quick in the recording, these will be lightning fast, and if not, the note will linger for as long as it's supposed to). And detail is a must.
I want something with the same sparkly highs (with no sibilance), lush mids, and deep extending bass (which, to me, is perfect as far as impact goes) as the Phonak Audeo PFE.
Maybe K702? Would that work?
My budget is around the price of the K702 (I want to cut it off there because I'm just figuring out what I should save up for. At the moment, I'm pretty much broke.)
And the cable must either be super durable or replaceable. These will be used at home. And because I'm not planning on buying them yet (this is more of a "know for the future" thing), I'm hoping to have an inexpensive amp by the time I have enough.
As far as amps go, maybe suggest an inexpensive amp that pairs well with the headphone you suggest (only if the difference between amp and no amp is a significant improvement over the headphone out of my S639F. Otherwise, I'd rather save some money. So if the headphone you suggest is very efficient, don't bother with an amp suggestion.)
