ccschua
- May 19, 2008
Oops. Item removed.
Originally Posted by bundee1 /img/forum/go_quote.gif does anyone know of a seller who sells the zero dac board seperatley? I might have fried mine. also can you replace a lifted pad with a ring made of clipped leads? in other words will the solder and ring continue the circuit? |
Originally Posted by okifaro /img/forum/go_quote.gif Dear All, I can not find on ebay .047uf 160V or .033uf 500V PIO's, what do you think, can it be replace with 0,047uF 250V PIO K42Y2? |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Nope...they (.047uf 250V) are too big in diameter (anything over 8mm will not fit). |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Nope...they (.047uf 250V) are too big in diameter (anything over 8mm will not fit). I wasn't kidding when I said it's getting harder to source the PIOs. I have some more kits in stock so anyone wanting one drop me a PM. Parts changes to the next lot of 10 kits. All PIO's are now .1uf 250V , this IS an upgrade(same diameter as previous .033uf 500V). Power supply section uses all Nichicon PW (1200uf 16V uprated to 1500uf 16V) Panasonic 330uf 25V FC/FM caps subbed for better Nichicon PW 330uf 16V Phase 2 changes: Panasonic FM's upgraded to 330uf 16V FC Phase 3 : Panasonic FM to FC Peete. |
Originally Posted by isao2k8 /img/forum/go_quote.gif Btw did anyone feel that original 47uF 10V SilmicII x 4 caps as coupling capacitors are better than 47uF 25V SilmicII x 4 in terms of SQ? I felt so...um... |
Originally Posted by isao2k8 /img/forum/go_quote.gif According to ussr-tubes.com, .047uf 250V K42Y-2's diameter is 7mm. So I think it can work. |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Those should be fine.....my mistake...the .047uf 200V K40Y-9's are too darn big and that is what I was thinking of with the previous reply. Les...not to worry, the difference in sound quality between the latest kits and the previous 12 will be minute if at all noticeable. Peete. |
Originally Posted by okifaro /img/forum/go_quote.gif Thanks folks. I've already ordered all first FrankenZero's specyfication caps with follow modyfication (problem with available some parts), do you think is that ok: CAP 4700UF 25V ELECT PW RADIAL NICHICON CAP 330UF 25V ELECT FM RADIAL PANASONIC - ECG DIODE ULT FAST 1A 1000V DO-41 MICRO COMMERCIAL CO (VA) V CAP ELECT 47UF 25V FM RADIAL PANASONIC - ECG CAP 100UF 25V ELECT AUDIO RAD ELNA AMERICA INC CAP 1500UF 16V ELECT PW RADIAL NICHICON 0,1uF 160V PIO Capacitors K42Y2 |
