whirlwind
I may have to try them as drivers....did you use the adapter and run two tubes as drivers ?
I really like the 6BX7 tubes as power tubes
No, when used as a driver, I run them one at a time.
While I have enough Fivre 6BX7 to use them as output tubes, I have found these adapters to be a bit too flimsy to allow me to do much rolling. Pulling tubes in and out seems to overly flex the plastic frames, causing the screws to come loose, and I worry that I might inadvertently break them. So no more rolling 6BX7 or 6BL7 as output tubes with the current adapters. I have four good ones installed now and plan to leave them as is. But eventually, I expect that I will get a second set of adapters....
So the only reason I run these tubes as drivers is to test them to make sure I haven't received a dud. And of course, at the same time, it gives me a chance to learn how they sound.
Thanks Ken...I will try one 6BX7 as a driver sometime and see what I think about it.
The EL3N adapters that take two tubes are even worse!
