J@CKY
- Apr 28, 2007
I recently switch from some other player to FB2K and trying to make myself understand the settings more.
I have some question about WASAPI component setting (well, more like a "output" tab setting).
In the output format section, I have the choice of 8-32bit. The default is 16-bit.
I have a couple of 24-bit/96kHz downloads.
In order to take advantage of the 24/96 recording I switch this to 24-bit setting.
My question is, if I keep it that way when it finished playing the 24-bit album, and start playing normal 16-bit files, what will happen? It has no bad effect? or will it play as normal 16-bit when the file is not up to 24-bit? or do I have to switch it back and forth manually every time I play different format files?
Thanks.
Thanks.
