Philski
- Oct 18, 2008
I have had a couple of issues with Foobar2000 recently, I'm hoping that someone can help.
After plugging my iBasso D10 into my laptop and turning it on, I don't get the option to select USB output in the Playback Preferences. However, when I do the same with my Pico, I do get the option. The D10 is fully charged and the whole chain is live - Pico -> amp -> headphones. Any ideas?
The second issue I'm having is installing some Foobar components that I want. When I try to extract the downloaded to files to the components directory of Foobar2000, I get a message saying 'Access Denied', explaining that the action might require Administrator access. The output log says:
"Extracting file: C:\Users\Philski\AppData\Local\Temp\foo_ui_columns-0.3.7.3.7z
Extracting to "C:\Program Files\foobar2000\components\"
Use Path: yes Overlay Files: no
Error: Access is denied
Extracting license.txt Unable to create file"
Can anyone help with this as well? Please bear in mind that I am not technical, but good at following clear idiot-proof instructions!
