Syliano
- Jul 22, 2010
Hey guys I got a little problem here. I use to own the Sennheiser HD600 paired with the Fiio E7+E9 for music production(mixing) for a long time, unaffortunately I had to part with the senns. A while after that I decided to buy the Focal spirit pro's because of the raving reviews. I like them a lot with the Fiio E7 alone, but they suck with the E7+E9 combi probably because of the low headphone impedance and high jack input impedance on the E9. It's just grainy and the highs are way to prominent.
Now there are a few options im considering, since I do want to keep using the E7E9 combi;
- Get a resistor adaptor (Etymotic ER4P to ER4S (3.5MM plug)resistor adaptor)
- Ditch the E9 and just use the E7 for the spirit pro's (which is not practical because I use the line out from the E9 for my speakers)
- Get the HD650 and sell the focal spirit pro.
What do you guys think I should do?
Could adding a resistor adaptor be a suitable solution?
If not will the HD650 with the Fiio E7E9 be a big improvement over the Spirit Pro paired with the E7?
Thanks in advance for the advice!
