Ordered a set, arrive tomorrow. If they’re tuned similarly or even more neutral than the Hadenys then I’ll be happy with them as a beater set for sure!
Focal Lensys
- Thread starter CheekerBreeker
Halimj7
- Mar 2, 2012
Looking forward to your assessment!Ordered a set, arrive tomorrow. If they’re tuned similarly or even more neutral than the Hadenys then I’ll be happy with them as a beater set for sure!
Kevintj604
Sounds good. I'm trying to track one down in Canada as my local store won't have any in stock for over a month.Ordered a set, arrive tomorrow. If they’re tuned similarly or even more neutral than the Hadenys then I’ll be happy with them as a beater set for sure!
alchemical
Really looking forward to your thoughts. Where did you order from?Ordered a set, arrive tomorrow. If they’re tuned similarly or even more neutral than the Hadenys then I’ll be happy with them as a beater set for sure!
Scan in the UK, but loads of places have them now.
Yeah I’ll try muster up some initial impressions tomorrow. I’m not one for reviews or detailed notes on equipment but I’ll see what I can do. I’ll either like them or I won’t but I think it’ll be the former
Received them about 20 mins ago. So far so good.
The mids are
Bass extends very well and I would say more textured than the Hadenys, more linear I think.
Overall maybe a like less congested sounding, cleaner, crisper.
They don’t sound like closed backs to me, no less open than the Hadenys (from recent memory).
The top of the headband seems plusher. The pads internally are a bit different, crunchier, but they settle in nice, probably a little softer.
See no reason not to have them!
Would have these over the Hadenys any day!
(Didn’t/Don’t have Azury’s to compare)
The mids are
Kevintj604
Perfect. I can't wait until I can get my paws on a set. Waiting for my local store to get their inventory so I can buy it.Received them about 20 mins ago. So far so good.
The mids are.
I don’t think you’ll be disappointed to be honest. I would without a doubt say that the Lensys is more refined than the Hadenys. Listening to this at the moment and it sounds great
alchemical
Appreciate the impressions! Definitely picking up a pair as soon as they’re in stock locally.
Halimj7
- Mar 2, 2012
How is the bass speed and treble? How would you define the tonality? Thanks.Received them about 20 mins ago. So far so good.
The mids are.
Haven’t done any specific “testing” but bass seems pretty tight, quick enough for DD (I’ve mostly been listening to planar recently). Haven’t picked up any looseness there to be honest.
Treble probably slightly elevated, perhaps, or that’s how I’ve perceived it. Not too bright, piercing, nor ‘light weighted’ .. it’s definitely present but not fatiguing for me.
Overall it’s like an energetic neutral(ish), possibly some would say sort of W-shaped maybe?
Only had 40 or so minutes with it but have to call it a night. I didn’t do any A/B with other phones either. Opinion may change on further listening. However, yeah, in isolation it’s a very good all-rounder for me.
So a better Hadenys (which was an improvement over the edition XS imo) but closed back? Sounds very interesting.Received them about 20 mins ago. So far so good.
The mids are.
How is the passive noise isolation?
ThEvil0nE
- Mar 30, 2010
Looks to be not internally wired balanced
Well, some might still prefer the Hadenys but for me yeah the Lensys is a nicer listen.So a better Hadenys (which was an improvement over the edition XS imo) but closed back? Sounds very interesting.
Noise isolation, it has some
