Slackaveli
Yep, which is medium gain for me. Listening between 11:00 and ~2:00The volume control is based on a relay attenuator and contains 64 steps. The control circuit uses Panasonic fast signal relays with low contact resistance. The analog signal is fed to the relay attenuator located next to the input sockets, and the ALPS variable potentiometer (Blue Velvet series) is used for control only.
In my experience it is always the best option to use the gain setting that allows you to listen to your preferred volume with the potentiometer at about middle position or a little higher.
As for low vs med vs high gain, i hear zero noise on all 3.
