Flux Lab Acoustics FA-10, FA-10 Pro, FA-12, FCN-10 & FA-12s Amplifiers - Summit-Fi for the People?: Reviews, Impressions & Discussion
Jan 8, 2023 at 5:55 PM Post #2,431 of 2,598
Jan 8, 2023 at 6:04 PM Post #2,433 of 2,598
Jan 8, 2023 at 6:05 PM Post #2,434 of 2,598
At $250 more than the FA-10 Pro, but with new internals but the same look as all the others, I'm more confused as ever over which model to eventually get. :sleepy: Calling it an FA-10 only makes it more confusing
Jan 8, 2023 at 6:06 PM Post #2,435 of 2,598
Jan 8, 2023 at 6:17 PM Post #2,436 of 2,598
Jan 8, 2023 at 6:52 PM Post #2,438 of 2,598
It would be nice to have a choice, but at the moment only the Limited and VOLOT Pre are in stock. According to the tests, the FA-10 Pro sounds much better than the FA-10. I think it's no coincidence that the Flux Lab Team has placed the Limited in the webshop right between the two.
Jan 8, 2023 at 8:20 PM Post #2,439 of 2,598
Look at it and you tell me.
Logically, that tells me that FA10 either can't drive Susvara properly, or there is unnecessary slurp going on. Either way, it's frustrating as a potential customer. Now I have no idea whether FA10 will do what I want or not.
Conflicting commentary is unhelpful.
Jan 8, 2023 at 8:32 PM Post #2,440 of 2,598
The FA-10 has no problem driving the Susvara’s. When I had my Susvara’s, the FA-10 was the first dedicated headphone amp that I thought did an excellent job with them. The Volot is just a much better version of the FA-10 built to crazy standards. I’d consider the Volot to be an ultimate amp for the Susvara’s, but it’s not needed. The dual mono design of the Volot does improve the sonics over the FA-10 which is single ended.
Jan 8, 2023 at 8:36 PM Post #2,441 of 2,598
Have you read any of the many reviews that are available to you? And all out assault on a premium headphone amplifier for 2500 is hardly slurping.
Jan 8, 2023 at 8:41 PM Post #2,442 of 2,598
So why does Volot exist then?
Technically Volot is internally balanced/differential. If your home power sucks and is noisy.....it solves your issue?
Also I think Volot isn't intended to be as colored sounding as the original FA-10 amp. Also FA-10 amp came out a long long while before VOLOT came into existence.
My biggest question about the VOLOT is why does it look like it is using big blue Motor-Starting caps that look liked they can be used in my home AC unit.
Jan 8, 2023 at 9:10 PM Post #2,443 of 2,598
Given what ‘Volot’ means, everything about the amp should be huge / larger than life!
Jan 8, 2023 at 9:39 PM Post #2,444 of 2,598
look like nippon chemicons to me, I assume it's just bigger is better, look like something you'd normally see as filter caps in a full size power amp
