wolfstar76
From your picture it is not clear, may I ask what is the DAC you are using for this setup?Here it is
None : just said above, I’m using directly either my Shanling M8 or Questyle QPM as sources connected to the FA-10From your picture it is not clear, may I ask what is the DAC you are using for this setup?
You are just right : a QLS QA390 but not connected to the FA-10Looks like a Quloos desktop replacement dap. I always been curious of that.
Yes, the FA-12 have the relay volume control attenuator. The problem I had was the rotary resistance is extraordinarily low and I had a hard time adjusting the volume smoothly up or down 1 - 5 decibels at a certain point on the dial. With small adjustment between relays the volume quickly jumps up 10 dB and back down. This was happening to me on medium gain at 12 o'clock on the knob. I speculate that my human touch is twitchy, and the low rotary resistance knob translated that information. To alleviate that, the felt pads smoothed out the adjustment. It seems to be working and I haven't heard volume twitch so far.Isn't it a relay steps volume adjustment implementation? Are there small adjustments between the r-2r clicks? Or that only in the FA-10?
Keep in mind that part of the issue is how the volume control is implemented on Flux ampsYes, the FA-12 have the relay volume control attenuator. The problem I had was the rotary resistance is extraordinarily low and I had a hard time adjusting the volume smoothly up or down 1 - 5 decibels at a certain point on the dial. With small adjustment between relays the volume quickly jumps up 10 dB and back down. This was happening to me on medium gain at 12 o'clock on the knob. I speculate that my human touch is twitchy, and the low rotary resistance knob translated that information. To alleviate that, the felt pads smoothed out the adjustment. It seems to be working and I haven't heard volume twitch so far.
Hi, thanks for your feedback.Keep in mind that part of the issue is how the volume control is implemented on Flux amps
In short the volume gain is not linear. Up to 12 o’clock it ramps up slowly in small increments and then ramps up more quickly as you go past 12
