The pontus Ii is at home ^^
Flux Lab Acoustics FA-10, FA-10 Pro, FA-12, FCN-10 & FA-12s Amplifiers - Summit-Fi for the People?: Reviews, Impressions & Discussion
- Thread starter teknorob23
The Holly Trinity!The pontus Ii is at home ^^
You are in for a treat!
Iggnasty
Any thoughts on the FA-22 been able to power the HE6SE V2?
wolfstar76
I believe there were discussions already in this thread. You can certainly power HE6SE V2 with FA-22, but the question is which one is better. I chose FA-10 based on my research for my HE6SE V2.Any thoughts on the FA-22 been able to power the HE6SE V2?
I love the sound with my FA-22. On High Gain the volume probably sits about 2 o'clock. I bought FA 22 for the mosfet Magic.Any thoughts on the FA-22 been able to power the HE6SE V2?
Have you guys any opinions on GOLDPOINT SW2X ? I intent to output from pontus2 to the goldpoint and one output to speakers and the other output to fa-12. I've research a bit and it seems to be quiet good.
Active preamp vs passive
wolfstar76
Just received my fa-10. I found that it makes clicking soud when you turn the volume knob when it is turned on. Is it normal?
XLR2XLR
It's absolutely normal. This is how all relay attenuators work.Just received my fa-10. I found that it makes clicking soud when you turn the volume knob when it is turned on. Is it normal?
Yes pretty normal, don't worry it is part of the magic!Just received my fa-10. I found that it makes clicking soud when you turn the volume knob when it is turned on. Is it normal?
wolfstar76
Thanks for the above replies. I just found out that I can plugin both my HE6SE and Sundara in FA-10. Of course, with moderate sound level on HE6SE it is already deafening on Sundara. Have to make a decision whether to keep my Sundara as it is redundant. I found that I have to use high gain and 3 clock to make HE6SE sound okay to me.
cfranchi
- Jan 9, 2016
3 clock! you should have really bad ear!
I like to listen loud and I’m around 1 oclock
Which pads do you use ? Did you check your drivers ? Defect HE6se can have drivers stuck to the magnet.
realmassy
My God, I usually at 11 o’clock on low gain with the Empyrean or the HD800s!
artist777
- Jan 31, 2011
How far you can turn the volume knob will also depend on the output level of the DAC. And this level is different for everyone, some have more, some have less.
wolfstar76
I am using all stock. I got Dekoni Elite valour pad, but could not find any difference and the fit is not as good as the stock pad. I also tried grill mod, again no impact. I indeed checked the drivers, they are not stucked. The bass impact is huge. BTW, 3 o'clock is for Youtuber music, for my local lossless music, I will tune it down to 1 o'clock.3 clock! you should have really bad ear!
Well I haven't done any long term listening yet, I need to say that for that purpose, 3 o'clock is definitely not healthy, if bearable.
wolfstar76
I am still using Schiit Modi 3, will upgrade it later.How far you can turn the volume knob will also depend on the output level of the DAC. And this level is different for everyone, some have more, some have less.
