Originally Posted by SysteX /img/forum/go_quote.gif From what I understand, no matter what compression level is used, decoding involves only integer arithmetic.
I never knew that. Cool beans.
I thought increased processing needed[therefore battery sucking] from FLAC8 was the price you paid for relatively smaller files. If not, its just paid for in increased encoding time.
...not bothered though, as I use foobar.
If it was the case, couldn't you just re-encode an 8 to 5 or less...
Originally Posted by SysteX /img/forum/go_quote.gif I'm sorry, but this is simply not true. The processor time needed to decode a FLAC file is completely independent of the compression level used.
Agreed. I use the highest compression since it takes no time for my computer to encode anyway. It takes way longer for EAC to read the CD then encode to FLAC
FLAC 0 can actually take longer to decode than flac 5 which is the default because it is a nice compromise between load and time but higher compression levels do use more CPU cycles (about 3% in 0 vs 5 which should be negligible). The added time for 0 may have to do with starting with more bits at lower cdompession levels but I really don't know. I'll have to try level 2 as I do prefer 0 to 5. I wont try to explain why because it would be a guess and I understand that there should be no difference on playback.
on my Galaxy Nexus, there's no practical difference in battery life between compression 8 and compression 5 for playback. The file size doesn't differ by very much anyway, so I always just use compression 8.
