Sam
- May 22, 2005
Hmmmm, I've just done a quick google and it would appear that EAC pays no attention to whether or not that encoder succesfully encodes the WAV, it just continues regardless.
If you want to verify that the FLACs are okay then it looks like you're going to have to do this seperately using the flac command line program and the "--test" option or use FLAC frontend (which you say you already have and would be the easiest way to do this).
Sorry to mislead you.
Originally Posted by kschul2 I was asking when using the -V in the command line and it verifies the FLAC encoding if there was a way to check if it was verified or not? Or does it just verifiy itself while encoding? Thanks for all of the help. |
