Edward Ng
Good day, all! I was doing a bit of research here and noticed that there are at least five portable players on the market that can handle lossless formats. From what I can tell, they are the:
1) Rio Karma 20
2) iRiver iHP-120/140
3) Apple iPod
4) Creative Zen Touch
5) iAudio M3
My preferable format is either Monkey's Audio or FLAC, as half my library is FLAC and half my library is Monkey's Audio; if the player supports either format, I need only rerip half my archive, rather than the the entire thing.
However, I did notice that the latest firmware for iAudio M3 only officially supports FLAC levels 0, 1 and 2. I'm positive I used the maximum compression (8?); will the M3 still play my files? If not, I'd end up having to rerip even my FLACs just for it! How about Rio Karma 20? I haven't been able to find if there are any compression level limitations for its FLAC support.
If I have to go with a format other than those two, I need to know if there's any audio player other than iTunes that supports Apple Lossless on PC. Right now, I use foobar2000 and I don't think it supports Apple Lossless (somebody please correct me if I'm wrong there). I don't like iTunes because it doesn't seem to have support for Kernel Streaming or ASIO output, or at least it cannot bypass Kmixer (again, please correct me if I'm wrong on that as well). While WAVE would certainly work, that'd really cut down on the amount of hard drive space I have all around, so I'd like to avoid WAVE if possible.
Another highly important item is if the player supports a standard line-out; I will be using a HeadRoom BitHead and Etymotic ER-4S, and I'd much prefer to use the player's line-out if possible, rather than the headphone out. I know the iPod supports this via an aftermarket cable; what about the other players I listed? It has to remain on the portable side, so carrying the dock would be a real hassle unless it's really, really small and all cables are detachable from it.
-Ed
1) Rio Karma 20
3) Apple iPod
5) iAudio M3
-Ed
