RotAtoR
- Mar 24, 2005
No, unless your decoder/playback software is broken or you have strange hardware problems, flac files decode bit for bit the exact same as the original PCM audio. The compression can't affect the sound quality because lossless compression has absolutely nothing to do with sound quality. The exact same digital input to your soundcard/DAC should give the exact same analog output.
Originally Posted by jagorev Am I the only one crazy enough to think there's a difference between CD-audio .wav files and FLAC? Especially with CDs of older recordings, some of the faint background hiss is gone with FLAC. And some of the peak frequencies seem to be strangely attenuated. I know the FLAC is supposedly 'lossless', but it does use compression techniques which at least change the character of the sound. |
