CloudColor
- Apr 14, 2009
I recently broke the jack to my DT770's, clean thru the 1/4 adapter into my 3.5mm.
This has thrown me into DIY audio projects, which isn't bad because i wanted to anyway and now i'm EXTREMEMLY motivated to fix my lovelies.
My goal is to make a few cables and then attempt to reterminate my 770.
It seems like for cables i can either make my interconnect myself (which sounds a bit more then i want to get into currently).....or buy the cables preassembled.
I'm simply overwhelmed by the selection of DIY products and wanted some insight
1. Recommended pre assembled interconnects. There are just too many options and i don't want to buy something blatently wrong. Quality isn't too big an issue as these are my test runs, as long as they are better then radioshack
mini - mini interconnect
1/4 - 1/4 interconnect
mini male - mini female interconnect
Need Cookies Enabled One of the few i've found, not sure if its under/overkill and if it will fit the neutriks?
Could i just use this one cable for my 3 projects?
2. I want to use neutrik plugs (i think) and i don't want to accidentally get cable that won't fit.
3. A recommended plug for my 770's, was thinking of sticking to neutrik
4. If possible i'd like to place only one online order, from somewhere like markertek
5. shopping list: 3 cables, 7 plugs, some heatshrink, maybe some tech flex for fun. did i miss anything?
Sorry for all the questions mixed in there I'm sure i'll have many more, and thanks for you help!
I will post pics when all is finished!
