mkarikom
- Sep 21, 2012
love these cans, but I have to re-adjust the headband often because it keeps slipping up the wires. anyone have a fix for this?
yeah, but I've got it pretty tight already and I don't want to strip the poly threading on the clampDoes the Ether 2 have a screw as well on the sliding plastic pieces?
Worth trying to tighten them a bit.
you could slide the plastic pieces a little back then spray a little hairspray on the 2 metal headband parts than slide the plastic pieces in the right position.yeah, but I've got it pretty tight already and I don't want to strip the poly threading on the clamp
