Bob came over, and we tried out a couple of things today.. one of which is the SuperDual alongside the Shure E5c.
SuperDual is definitely overall, a more balanced, better amp than the previous Xin efforts. The sound is fuller, richer, more of a balance between lows and highs, and more controlled than previous versions.
Would I say it's better than the likes of XP-7, PPA, or even a maxed out Meta? Not really... It's still impressive for an amp to sound this good from this small size, but it's all relatively to the size. However, if it does sell for $99, it'll be very, very competitive with other amps in its range (it should be better than most of them).
There's still a slight "hissing" problem with the Shure E5c, but it's much more subdued. It's less than the level outputted by the SuperMicro, and the Supermini. To the point where it's almost completely noticeable even during music playback with black notes. It's definitely still there though.
The combination of the SuperDual and the E5 though... just produced some of the biggest bass out of any amp+headphone combination that I've ever heard. If you're a basshead, you're just going to love this combination. This is definitely a quantity of bass, not as much quality as higher level amps will provide. However, at the proposed price, this is very, very impressive yet again.
One glaring problem though, both Bob and I hope this was some sort of a bug in the amp. The cross-feed switch doesn't seem to be working or doing anything. In fact, it seems like everything is completely and fully crossfed. What does this mean? I have couple of songs I use specially to test 3d imaging, and all the sound that used to come from the different sides has now all been moved to completely front of me. Which also means.. it's almost like this amp is giving me a mono signal!!! There's no left and right separation whatsoever, and regardless of what we did with the crossfeed switch, it doesn't do anything.
Just for the sound itself, there's definitely a good quality to them, and I can't really think of an amp at this price range that really offers the same type of performance and portability. I'm hoping what we found was a bug of some sort.
Overall, this amp isn't bad, considering price, size and performance. It is definitely not a high class amp though, not anywhere near the class of XP-7 or PPA or anything alike. However, if it so turned out the 3d imaging problem isn't a bug.. then I would stay away from this amp completely, complete lack of stereo image is not acceptible.
cmascatello, did you experience the 3d imaging problem as well?
