morph2k4
- Oct 22, 2010
I'm looking at starting my first real recabling project, and was hoping to get some advice about what to start with. I want to make a custom silver wire for my SA-5000, but I'm a bit unsure of a few things.
1. Is there some reason the Silver Dragon cable is so cheap? It seems to come in at around 2/3 what the raw wire costs from HGA. 1 foot of silver dragon is 20 dollars, and that is sleeved in rubber (is there a name for the rubber sleeving?). The HGA wire costs 30/foot, and does not have the same sleeving. Silver Dragon seems like an unbeatable deal.
2. Is there a specific name for the plastic piece that houses the split in a headphone cord where the two driver lines separate? I recall seeing a plastic adapter available somewhere, but I don't see it on HGA or moon-audio, and I'm not sure what exactly to search for.
3. Are there some sites I should be looking at other than HGA and moon-audio?
4. Does one typically add a nylon sleeve on top of the rubber sleeve that the Silver Dragon has, or is the nylon an alternative sleeving option?
5. Is there some particular type of connector that is better suited to detatchable cables then a 3.5mm mono plug? I modded a pair of grado's to have the cables disconnect this way, but I found that the mono plugs pull out easily. Is there some standard locking jack that would do a better job?
Thanks for your time, any help would be greatly appreciated
