I have a Cakewalk UA-1G and i want to put it inside an old external hard drive case, change the 3.5mm headphone out to TRS (balanced or unbalnced) outputs and turn the headphone scroll dial into a rotary pentometer. Essentially I want to turn this into a more solid desktop DAC. The reason i want the TRS outputs is so that i can run my Mackie monitors out of it and use the rotary pentometer to control volume; I'll be using the RCA outputs for a headphone amp.
My questions are as follows: How hard would it be to do the TRS mod? Could I change the scroll wheel to pento? Would I be able to extend some of the inputs by soldering wires into to make them longer?
