Dear friend,@FiiO, will gapless over Bluetooth be fix in the firmware update?
We will help report your issue again to the engineer for checking for you.
Best regards
Sorry, will be delay.
Dear friend,I sure hope the update comes out soon, cause I really like the X1 II, but the bugs are just ruining it for me. The response time via Bluetooth is terribly slow, but this is something I can live with. However, not being able to connect a device via BT? That's ridiculous. It took several times to finally get the Xiaomi Bluetooth Audio Receiver to work. Also, I really hate it when I turn the screen on to check the song that is playing, and a completely different one shows up. What's up with that?
Dear friend,Hi, I have an iPod Classic (160GB) in wich I have some ALAC albums.
My question is: Will FLAC files played on a Fiio X1 II sound better than those ALAC files on the iPod?
I guess that the Fiio has much modern and better components, but I don't really know if it will be a difference in the quality and clarity/detail of the sound, because the ALAC is also some sort of losseless file format.
The headphones I use are Grado SR60e, Audio Technica ATH-M50x.
Sorry for my english and thanks in advance
Dear friend,Tried searching but could not find an answer.
If the X1 is paired with a smartphone using Bluetooth would it act as an intermediary between the earphones and the smartphone? In other words, if I get a call on my smartphone will I be able to use the remote and mic on my earphones to answer the call and talk normally as if the earphones are plugged directly into the smartphone? If not, would I at least get a notification that I'm receiving a call.
It is annoying to use a dedicated DAP and not hear one's phone ringing, thus missing calls.
I do not want to stream from the smartphone. I prefer to use the DAP. The problem is that if use a dedicated DAP I miss a lot of calls, as I do not hear my phone ringing.
Even if I am not able to use the remote and microphone on my earphones to answer the incoming call and talk, at least a signal of some kind would be nice, i.e. the phone to ring "through" the DAP so that I know I'm getting a call so I can pause the music myself, take out my phone, and accept the call.
