PROblemdetected
Previously known as sakt1moko
Any chances of roon ready for the q7?
Don't think so. Wouldn't the Q7 have to have wi-fi?Any chances of roon ready for the q7?
Why not? Its an stationary usb dac as well.Don't think so. Wouldn't the Q7 have to have wi-fi?
You need.Don't need wifi to get the ready check
Well, for ready maybe, but for"roon tested" don't.You need.
Roon plays via netwrok/wi-fi
Q7 it is usb/bluetooth-dac/amp
Connect Q7 to roon end point (e.g. raspbery pi, or more expensive) and you will get roon-ready device.
I have Roon on my laptop. USB out to the Q7 works great. But no way to output to the Q7 wirelessly without bluetooth.Well, for ready maybe, but for"roon tested" don't.
Im talking about usb - roon tested.I have Roon on my laptop. USB out to the Q7 works great. But no way to output to the Q7 wirelessly without bluetooth.
Okay, so did I answer your question? I said USB works from Roon to the Q7.Im talking about usb - roon tested.
Any dac works on roon.Okay, so did I answer your question? I said USB works from Roon to the Q7.
You should not use such extreme gain for very sensitive transducers like IEMs. It is mainly for low sensitivity headphones that need a lot of power.3. When Ultra High Gain is turned on, a low-frequency hum (50hz) is heard in the FH9 headphones. Touching the connector or the metal part of the Q7 case with your hand removes the hum. In other modes, everything is perfect. With other headphones there is no hum.
Yes it works with the Q7 but I am not sure if it is global effect or only in Bluetooth mode.Does the Q7 work with the fiio app, particularly, does the EQ work on the Q7 on the fiio app?
Dear friend,Yes it works with the Q7 but I am not sure if it is global effect or only in Bluetooth mode.
