The Story of FiiO Portable Desktop-Class Amplifier Q7
Chapter 4 Design ideas- Making a portable device basede on desktop concepts
Today we are going to talk about some design ideas of the Q7, which designs on the M17 are continued and some new designs that are different from the M17.
A copy of the M17? (See picture 1)
From the appearance, it is very intuitive to see that the Q7 is an M17 without the playback function. Indeed, this was our original idea. Because the M17 itself adopts the separate digital-analog section design. Therefore, by replacing the digital section with decoding amps, we can smoothly iterate a high-performance DAC/Amp.
This was a discussion thrown by our CEO James after the release of the M17. It received positive feedback from users.
Pictures 2 and 3 are the internal PCB diagrams of the Q7 and M17. We can see that the layout of the two products is very similar. The analog board is the commonly-used single ES9038PRO, while the digital board is replaced by our newly designed core board including the XMOS XU316 chip.
Surveys and discussions are just a guide, and the focus is on user feedback and needs, as well as the actual evaluation of subsequent projects. As the current supply environment and the economy are frustrated, it is indeed difficult for us to make products, and there are many constraints. Based on the development of the M17, it is a democratization of cutting-edge technologies, not necessarily a complete copy.
First, we have continued the widely recognized designs on the M17 to the Q7.
- External power supply design similar to desktop devices, which can provide more abundant power supply than batteries.
- Up to 3W output amp circuit, suitable for ear buds and full-sized headphones.
- Comparable to the 9200mAh battery with the capacity of the mobile power supply, which can guarantee more than 10 hours of battery life.
- In addition to DC and battery power supply, energy storage is also closer to desktop devices; also, super capacitors and multiple aluminum electrolytic capacitors ensure sufficient dynamics.
- Features a standard USB-B optical port and RCA coaxial port, which can be connected to the audio source without an adapter cable.
Second, some audio configurations have also been retained.
- A single ES9038PRO DAC that flagships will definitely choose.
- Fully balanced audio circuit for better crosstalk and dynamics.
- The audio channel uses high-precision film resistors with low temperature drift, low noise, and low-loss film capacitors to ensure audio reproduction.
- 5-level gains that support supply voltage adjustment and hardware amplification adjustment, which can adapt to a wider range of headphones.
