godog
- Oct 1, 2005
Can the rgb light be turned off?
According to the Q7 specs page:Apologies if I have just missed the information somewhere. What are the power output specs at higher impedances?
For those interested, there are also some measurements under the link:Looks like a full MQA decoder with the ES9038pro. And has balanced LO.
Here's the specs:
https://fiio.com/Q7_parameters
Yes. Should arrive soon.
I'd be surprised if there was a significant difference between having one or two DAC chips. I'll test and find out.
The ES9038PRO is an 8 channel DAC chip that can be operated in fully balanced and differential mode with one piece only.Well at least folks won't have to ask if SE output uses both DAC chips. Unless there is such a thing as the single DAC chip operating in half mode.
So you mean that when i plug my headphones with 3.5 mm jack in my M17, it will use only one dac chip in music playback?The ES9038PRO is an 8 channel DAC chip that can be operated in fully balanced and differential mode with one piece only.
Yep - and only one amp module too. That's a big reason why balanced connections have much more power available compared to single ended.So you mean that when i plug my headphones with 3.5 mm jack in my M17, it will use only one dac chip in music playback?
Interesting - I swear I have always heard otherwise... unless it was a different situation in some previous FiiO products?No.
Both DAC chips and amplifier modules are used and then a balanced to single ended convention is used for the single ended output.
In your example, where does the output from the lower THX amp connect to the single-ended output? It doesn't appear to at all. If that is the case, then only the upper amp is used to drive the single-ended output, and therefore only 1 amp is used for SE, but both are used for balanced.The working principle is like this.
I can't find the M17 schematics but I am attaching one from the M11 Plus.
Yes regarding the amplifier module you are absolutely right.In your example, where does the output from the lower THX amp connect to the single-ended output? It doesn't appear to at all. If that is the case, then only the upper amp is used to drive the single-ended output, and therefore only 1 amp is used for SE, but both are used for balanced.
As said before, dual DAC ES9038PRO is anyway an overkill, mostly to satisfy the audiophile more DAC chip hunger. RME ADI-2, for example, uses only a two channel ESS chip and performs far beyond the limits of what the ears can hear. For your question, multichannel (more than two) DACs have a stereo mode where 4 channels are assigned to left and the other 4 to the right. AKM 4499 DACs which are 4 channels also can use 2x2 configuration. 8 channels are actually for surround implementation. From ES9038PRO datasheet, check stereo mode:Well at least folks won't have to ask if SE output uses both DAC chips. Unless there is such a thing as the single DAC chip operating in half mode.
Dear friend,Apologies if I have just missed the information somewhere. What are the power output specs at higher impedances?
Output power |
1500mW (16Ω,THD+N<1%) |
1100mW (32Ω,THD+N<1%) |
130mW (300Ω,THD+N<1%) |
Output power |
750mW (16Ω,THD+N<1%) |
550mW (32Ω,THD+N<1%) |
65mW (300Ω,THD+N<1%) |
3000mW (32Ω,THD+N<1%) |
500mW (300Ω,THD+N<1%) |
1500mW (32Ω,THD+N<1%) |
260mW (300Ω,THD+N<1%) |
