Wow.. TQ.. Does it requires any wire cutting and soldering or it is just as simple as attaching the connector.Dear friend,
Because of the strict customs here, we could not arrange the pure battery shipment to other country now.
But you could try to find one from Aliexpress. This one is recommended by other user: https://www.aliexpress.com/item/4001197407095.html?spm=2114.12010615.8148356.7.677e6b00V4XrcD
Best regards
[FiiO Q5s Type C ‖ Q5s] Bluetooth DSD-capable Amplifier,AK4493x2,768k/32bit
- Thread starter FiiO
MotherGooz
- Feb 10, 2012
just a simple detaching the old wire and connecting the new battery wire.
- Sep 5, 2010
Dear friend,
Which output port are you using? And it seems that the Q5s doesn't have 1.4 firmware.
Best regards
This is what it says in the Fiio control app. Anyway, I just updated to iOS 14.4 and it seems problem has vanished
- Sep 5, 2010
A further update. I’ve now used the Q5s TC THX AAA with both my iPhone 12 Pro Max and now my Samsung Galaxy S21 Ultra. Awesome sounds. I really like it with the S21 Ultra.
Glad to hear about that. Thanks for the feedback.
Best regards
Best regards
BROKEN1981
I just bought the FIIO Q5S TC from B&H. It hasn't arrived yet. What I would like to know is if I can use any charging brick to charge it. Will the Q5s TC control the current? Also when battery is full, will the device stop charging to prevent over charging?Glad to hear about that. Thanks for the feedback.
Best regards
Just got my unit delivered, and yes, it does seem to stop charging once all 4 LEDs is lighted.I just bought the FIIO Q5S TC from B&H. It hasn't arrived yet. What I would like to know is if I can use any charging brick to charge it. Will the Q5s TC control the current? Also when battery is full, will the device stop charging to prevent over charging?
Hope you enjoy yours once it arrives.
Rudivanb
Does some of you also have the issue that the Q5S mostly wants to play audio via Bluetooth, even thought in the Control App, charging via USB is set to OFF. Sometimes I get it, by pure luck, to play audio out of my phone via the USB cable. @FiiO Kang : Would there be a procedure to follow to get it to work always easily?
BROKEN1981
Awesome! Also how did you charge it? Right now my PC is dead. Motherboard died. I have a few charging bricks but they are all fast chargers. Will it be fine?Just got my unit delivered, and yes, it does seem to stop charging once all 4 LEDs is lighted.
I am just using an old iphone charger with a. USB A to USB C cable.Awesome! Also how did you charge it? Right now my PC is dead. Motherboard died. I have a few charging bricks but they are all fast chargers. Will it be fine?
The charger gives some 1A output, probably not going to kill it as it is rather small by today's standard. I guess.
U have to select the input audio either through the USB input button on the left side or BT connection on the right side and make sure the USB cable is appropriately connected in line with the arrow indicators if u r using the USB connection.Does some of you also have the issue that the Q5S mostly wants to play audio via Bluetooth, even thought in the Control App, charging via USB is set to OFF. Sometimes I get it, by pure luck, to play audio out of my phone via the USB cable. @FiiO Kang : Would there be a procedure to follow to get it to work always easily?
The charging option to On or OFF should normally be selected at Fiio Control Panel.
... I have a few charging bricks but they are all fast chargers. Will it be fine?
FiiO's page "https://www.fiio.com/q5stypec_comparisons":
Under " Power and Battery " section, it said "DC5V 2A (Recommended".
Will your fast chargers give more than 2A?
chichaphile
certainly not faster, cause limited by internal usb power limiter but i preferred slow 1A charging to minimize heat ( heat is lithium battery enemy )
I don't think that Q5s internal charging structure support the fast charging feature. But any charger even with the fast charging features will work ok with Q5s and to be safe, make sure it does not exceed the recommended specifications of 2A.FiiO's page "https://www.fiio.com/q5stypec_comparisons":
