Totoro8604
quite shocking people buying without taking time do some research. Me on the other hand not owning pc / laptop able to upgrade with no issue.. believe me read more perhaps you can find your answer ![Hugging face :hugging: 🤗](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f917.png)
How can you upgrade the software without a pc/ laptop?quite shocking people buying without taking time do some research. Me on the other hand not owning pc / laptop able to upgrade with no issue.. believe me read more perhaps you can find your answer![]()
You can't.How can you upgrade the software without a pc/ laptop?
If it had high res Bluetooth, a volume wheel and buttons for track skipping yes.Buy qudelix t71 for eq
Dear friends,
1. For the 24bit and 32bit selection problem, we will improve in later firmware update.
2. For the PEQ saving problem, the engineers are checking as well.
Best regards
buy a windows PC - your fault for having mac, you can't expect Fiio to cover niche productsNot being able to update via Mac or any mobile device should also be addressed.
100% agree. This is 2024.Not being able to update via Mac or any mobile device should also be addressed.
Have fun with your blue screen of death PC.buy a windows PC - your fault for having mac, you can't expect Fiio to cover niche products
