I have neither of the devices. M3pro has a dac and JWD does not, output is lower ( 70mw vs ~125mw on JWD ). Fiio products are very well made, refined and clean sound. But you will be missing out on BT, Wifi streaming capability and less power. Also, no EQ on fiio.
[FiiO M3 Pro] Fullscreen High-Fidelity MP3 Portable Hi-Res Lossless Music Player
- Thread starter FiiO
Dear user,New filters option in FW1.1.0 doesn't work at all for me. Switching between filters makes no difference in sound signature. Can anybody confirm that?
I own LG V20 and G7 with ESS DAC and changing filters makes huge difference.
The filter difference may not be quite noticable, but we test via oscilloscope and confirm the filters work.
Best regards
Dear user,I have neither of the devices. M3pro has a dac and JWD does not, output is lower ( 70mw vs ~125mw on JWD ). Fiio products are very well made, refined and clean sound. But you will be missing out on BT, Wifi streaming capability and less power. Also, no EQ on fiio.
You could find the EQ function in settings-play settings-EQ in the M3PRO.
Best regards
Dear Fiio, I just wanted to say thank you for adding the custom volume button function.
Kind regards,
Kind regards,
vas-tomsk
Dear FiiO, can you raise the album title up? So that it is above the cover art. Then the album name will be near to the artist name and the track name. It will be more beautiful and logical than it is now.
Adriatica
can it be that these Chinese make fun of us? we need a self-adjustable equalizer. EVERYONE who can reduce the damn heights, the Fiio M3Pro is tuned way, way too bright! that hurts your ears !!!! It can't be that difficult, can it? what shoud that ??? I'll give you another 2 weeks, then I'll burn this Fiio M3Pro! self-adjustable equalizer !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You seem a lil upset :^)can it be that these Chinese make fun of us? we need a self-adjustable equalizer. EVERYONE who can reduce the damn heights, the Fiio M3Pro is tuned way, way too bright! that hurts your ears !!!! It can't be that difficult, can it? what shoud that ??? I'll give you another 2 weeks, then I'll burn this Fiio M3Pro! self-adjustable equalizer !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Anyways, I'm not really sure what exactly these newly added filters do, is there any thing I can read that goes a little more in depth? Also, sometimes the player still resets when playing music, and lags for large playlists, is this because of lack of memory to handle large playlists and large song queues?
Dear user,Dear FiiO, can you raise the album title up? So that it is above the cover art. Then the album name will be near to the artist name and the track name. It will be more beautiful and logical than it is now.
Thanks for the feedback. We will report to the designer to check whether change the designer in later firmware update.
Best regards
ok this is ridiculous firmware update and no custom eq still.
the player sounds good but the highs are hurting the ears like someone said earlyer.it is tuned clearly whrong in the highs region...highs piercing the bran,distortios in the mids and highs in high volumes...
the eq options are fixing these issues but making the sound really boring and dull.
on early posts fiio said that a custom eq is in development or something.maybee they where just thinking to develop a firmware with it
now two firmwares have released and no custo eq to bee seen.
DEAR FIIO,TELL US THE ENGINEER S WORD CONCERNING THIS!
is custom eq realy in the making but yet to be rekeased becouse its hard work
or is it just not being considered to be done
PLEASE BE SPECIFIC THE PLAYER IS OF AMAZING BUILD QUALITY AND POTENCIAL a custom eq would make it king of the 100 dollar range shame shame shame the potential of the dac is being lost is it realy that hard to develop a damn user equaliser and make the m3 pro the colest budget player ever?
fabiodrums
I want buy M3 Pro. Is compatible with OSX? I read that when you connect it, the Mac does not read the player and to load the music you have to do it by removing the sd card and to do drag and drop into it. Not load via cable? Possible?
Dear friend,I want buy M3 Pro. Is compatible with OSX? I read that when you connect it, the Mac does not read the player and to load the music you have to do it by removing the sd card and to do drag and drop into it. Not load via cable? Possible?
You could switch the usb mode to storage from system setting. Then the MAC computer could read the M3PRO's SD card after connecting the M3PRO to it. You don't need to remove the SD card from the M3PRO and use an extra card reader for help at that time.
Best regards
fabiodrums
Dear friend,
Best regards
Ok, I’ll try it.
Thanks
You are welcome! Hope the M3PRO could meet your need.
Best regards
Best regards
fabiodrums
I've a question. I didn't find any information. Does it have fm radio?
There's no radioI've a question. I didn't find any information. Does it have fm radio?
