@FiiO
Hi, thank you for replying!
All that said, "within 200ms" is a pretty large range, is it 10-30 ms or 150-200? Both are within 200 but very different experiences for the user.
I tested it with some streaming services in a browser, some movies locally in Windows Media Player and a couple of games. I don't have clear steps to reproduce the issue and it doesn't happen often, but it was very noticeable when the lag was happening vs normal operation. Sound quality in Windows 11 is set to 384kHz/32bit, the only non-default setting in FiiO Control App was activating the Options tab via a config file change and switching Streaming option from "On when needed" to "Always on" (which I've since reverted to the default setting).1. According to our test, the USB DAC delay of M23 is within 200ms. Are there any other certain setting in your computer? Does the problem happen when using other APP?
Alright but could you confirm that the battery still very slowly discharging when plugged in is a normal behavior when D.Mode is enabled and Super Gain is available in settings?2. When the charging port(any C port will do) is connected to a fast charging adapter that supports PD3.0 or above protocol, the Super gain option could be enabled. When USB is inserted and D.MODE is displayed ON, it means the Desktop Mode is enabled. D.mode enabled or not will not affect the activity of Super gain option.
