FiiO M15S Pocket Desktop-Level Player Discussion & Impressions Thread
Nov 9, 2023 at 3:49 PM Post #691 of 953
Any sign of Android 11 or 12 coming along?
Android update .Forget about it.
Nobody has any interest in this.
You have to buy a new model.
I haven't heard of any DAP having updated Android, certainly not in FIIO.
There will soon be a new DAP M23 with what Android version.(Android 14 is already available in 2023).
In a moment there will be voices saying that it doesn't matter in DAP, for DAP there is no,
but it is for applications that you want to install in DAP.
Because the applications will not support old versions of Android.
Example: first version of FIIO M15 (great sound), old version of Android 7 - this is currently the minimum for Tidal and will soon die due to the system. :cry:
Nov 10, 2023 at 5:15 AM Post #693 of 953
At last the system level PEQ!
Nov 10, 2023 at 7:44 AM Post #694 of 953
Hiby did update the original R6 from Android 6 or 7, to Android 8.1, so it can be done, but is there a will to do it?
The reasons for wanting the most recent Android version is better power and battery management, up to date security patches and longer support for 3rd party apps.
Nov 10, 2023 at 9:59 PM Post #695 of 953
Can you guys plug/use 2 different IEMs or cans on the M15s outputs? I heard it's possible to do thay with the M17.
Dear friend,
No, the output will be given priority in the order of insertion.
Best regards
Nov 10, 2023 at 10:09 PM Post #696 of 953
Dear friend,
The M15S uses Qualcomm Snapdragon 660. The project supplier provided Android 9 and Android 10 for us based in Snapdragon 660 platform. And we have chosen the latest Android version provided by the supplier for M15S.
Best regards
Nov 13, 2023 at 2:04 AM Post #698 of 953
@FiiO
would it be possible to add a function that the display will turn on to show volume shortly when turning the volume knob?
Dear friend,
Do you mean that when you turn the volume knob, the display only shows the volume and nothing else?
Best regards
Nov 13, 2023 at 4:01 AM Post #700 of 953
Another suggestion if i may @FiiO
I have both m17 and m15s, it would be great to add a 'DC in' active status icon on the status bar row where the batt level etc are located.. So when the DC mode is on, we can directly know it from the status bar. And when its not, we can also know it easily. This should be especially useful for m15s when using powerbank..
Thanks
