[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
May 21, 2021 at 9:53 PM Post #122 of 3,145
Yes you can.
But if you want to use Apple Music be careful with the soc used by DAPs.
For example, M11/M11 pro/M15 does not support Apple Music because they are using Exynos 7872.
Only M11 Plus can use Apple Music.
Currently I'm on Deezer but I am considering going to Apple Music. I'll definitely get the M11 Plus then just in case I want it.
May 22, 2021 at 4:47 AM Post #125 of 3,145
Can Fiio M11 plus Playback Dsd512 files as stated in the picture
May 22, 2021 at 5:43 AM Post #126 of 3,145
@JamesFiiO @WianFiiO Quick Q: will the alloy and the SS LE come with leather cases? Thanks
May 22, 2021 at 4:50 PM Post #128 of 3,145
Does anyone happen to know how easy it is to go about swapping the battery in these devices? I'm super super tempted to get one. But for 1000 Canadian, what happens after 2-3 years when the battery is degraded badly. Anywhere in in Canada you can go to, to get it changed? Or is it easy to DIY? Where would you buy a new battery?
May 23, 2021 at 10:46 PM Post #130 of 3,145
We do not recommend users to replace the battery by themselves. This is very difficult. Generally speaking, the capacity of the battery will not drop too much in two or three years. If you really need to replace the battery, you can return to the factory for replacement.
May 23, 2021 at 10:47 PM Post #131 of 3,145
@FiiO Will Amazon USA receive any of these limited units? Will you be selling directly to US customers on your site?
Hi, yes, it may come on next month.
May 23, 2021 at 10:49 PM Post #132 of 3,145
May 23, 2021 at 10:52 PM Post #133 of 3,145
Hi, this shows the parameters of the DAC, for M11Plus, since the SOC can only support up to 384kHz at present, it can only support DSD256 playback at present, but we are currently studying how to make the main control support 768kHz, and then it can support DSD512 playback.
  • XTF1
