majo123
- Jan 1, 2016
I have owned Dx200 amp 8, Hiby R6 Pro and m11... All have flaws but all equally are excellent daps.
The ibasso battery life and build are not on par with either r6 pro or m11, infact having to charge a dap for hours just to get 5 or 6 hours play back for its cost is pretty bad in my opinion and I heard the 220 isn't much better. The ui on the 200 is out of date too and clunky and needs to run separately to the android.
Audio with amp 8 is pretty good though but is it worth it's value with the above other points I mentioned?
R6pro is fantastically built with excellent ui and more on par with its cost, the audio is pretty good too with a more fuller poweful sound, yes the treble is a little rolled off but not to the degree its a game changer in my eyes... It does have a little hiss but again I feel this is more power and mastering related than anything as poor or older recordings seem to show this up more, it also reportedly suffers interference from phones, again this is minor and virtually never happens and when it does your phone would have to be on top of it.
Fantastic dap and I kept it over the 200 amp8.
The M11 is the best dap fiio have made by far, in short it sounds good with slick ui, ample storage options and great build and screen. No real major faults although it may be a bit neutral for some.
If I were to choose between the 3 (obviously I'm going on the 200 here although I heard 220 isn't so different)
I would choose either the Hiby or the M11.. The Hiby is fantastic and excellent build with a big bold analogue sound, nothing ever sounds bad on the Hiby.
The M11 is a bit more neutral with less bass and a bit brighter tonality but still sounds great and can't fault it.
Sorry ibasso but your battery life/charging and build just aren't in the same league in my eyes although with amp8 it did sound good.
My 2 cents.
My 2 cents.
