Ironically Simple
EDIT - NVM I got confused. Been working with PCs my entire life and I can’t believe I got confused about storage.
I should be asking, What is the fastest speeds the Fiio can transfer or is it able to transfer data at the highest theoretical R/W speeds Micro SD cards can produce?
Does it matter what the R/W speeds are on the DAP, does a higher R/W speed load up the music faster or is it negligible?
Cheers
-Hugh
Cheers
-Hugh
